Just like to say that I in no way mean to be disrespectful of any service men and women that served in the vietnam war and any mental or physical pain and anguish that they may be still going through by my last post!
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hay ska......you fitted that pod? *hatches devious plot to keep ska awake*
Nooooooooooooooooooooooooooooooooooooooooooo
OK now this is last post, turning computer off after it, nope have not yet, was thinking of going round to strutto's place tommorrow arvo to get his expertise help to fit it, areyou available strutto, bugger it now I gotta wait,
But of course... The //GC Pit is always open...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
