  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
we used to order milk shakes then throw them at the perosn at the window. I used to think that was funny
that's called a " fire in the hole " drill , it has been tried and tested and still brings a tear to my eye
hehe.. yeah, i guess i better do that.. although i am kinda zonked right now..
i reckon its the planeteriam carpark (unless its closed at night ?? quite possible??) then up to mt cootha.. look around, go a bit further.. hopefully there is some sort of destination that general direction.
I really want to check this out , anyone live Kedron way ?
