  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
s there anywhere to go once you get to the top of mt cootha? or just back down
see i don't know these things :) Only been there once during the day.. to be honest I'm happy just to sit around for a bit and chat, and maybe go for a small run. Not up for anything maniacal at the moment
yeah but im a commo driver. if i can get a lift in a SILVER R33 4 DOOR THEN I WONT BRING IT OUT. LOL
just after a lift as well , as I am on crutchers for another week at least and don't get my line back for about another 2 to 3 weeks
did he actually see you yesterday when you drove past yesterday Adrian?
Certainly looked like he did... Apparently he's a little cranky at me? No idea why... Was quite pissed at Ska for even contemplating inviting me on there little weekend adventures...
I wasn't going to go... But I think I am obliged now...
How about Skas' proposal which included Stamford?????
that sounded quite entertaining
That sounds quite enjoyable Gordo...
Oh, you were spotted in the Who is Who thread too.... :wavey:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
