  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
255's on the front!  DAMN!...
I've got 225's on the front and they probably need to be slightly wider so 235's should be good...
hmmmm....the previous owner had some strange ideas when it came to handling :)
