  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hey chaos if you dont have a lift I'll pick you up and we'll go to the meeting spot then cruise back to your place drop you off, sound good? Better than nothing I guess, hope you know where the meeting spot is :rant: If you can hitch a ride from the meeting spot your set!
