so it is definatly mine? i can start telling people :rant: mmm cant wait to see works face when i quit
Well the job is yours on the two factors:
1. You still want it once you have see what you have to do.
2. The production manager is happy with your work effort.
If you can fill out those two criteria then you have a job here as long as you want basically!
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
you should storm out in the middle of a shift infront of a full counter and scream " You mean I have to wash my hands EVERYTIME I go to the toilet , not just the first time "
hmmm i'll work hard dont you worry :rant:
I dont doubt it, but as I said once we start hiring you'll be first on the list of people who get called for "interviews" which are just like 5 mins of this is the work, this is the pay, when can you start. And they rest is up to you bud!
cheapest rims for the 33 are the stockies/200sx rims. I had about 4 sets of them in melb :rant:
Generally go for about $400 with some tyres.. but don't seem to come up much in brisbane here. No idea where the old stockies go when people upgrade! probably back of some dodgy wheel workshop
What's the new job going to be ???/
Wooden truss manufacturing, he'll probably start off counting ancillaries and then either move onto the presses or saws, depending on openings and how hard he works.
Hey do you have your forklift ticket? If not if you get one then you could get one of the fork driving jobs, man that is sweet, drive a forklift round all day loading and unloading trucks!
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
