  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah cusco $80 if u still want. I wont be out thursday nght no more cos my grl got beatan up by sum guy last nght so ima going hunting.
Can I come and pick it up from your work on thursday?....I have the day off
Who the hell does that s$%t , matbe the crooz should be all ok us around your area , a bit of a SHOCK AND AWE campign , and smash the mofo
zac: you're not just going up to some guy who your girlfriend *reckons* is the guy?? seen stupid shit like that happen.. wrong guy gets smacked.. turns around with 10 of his buddies.. and entertaining violence ensues.
