  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah im just going back to the club n ima find him apparently a reguler at the club. last thing my grl said to him was ur a dead man walking. n if any of u guys know me then that is ***in true no one touches my grl.
And yamutha33. dont come to my work as they dont know what i am doin the only reason why im getting the parts so cheap is cos im saying there for my own cars or there 4 a race car me and a friend are building. Just deal wit me and u will get shit a lot cheaper
OK...when can I pick it up then.....patience is not one of my virtues :(
hmm PM me who wants what and I will see what I can do ok. Cant promise anything cos we might sell it at work anywayz but if I get my hands on them there up on dis site k.
and yes pred cos she knows the guys face and so does her friends as they are alwaz at the same place. N trust me I aint going alone. I fight alone but if back up is needed it is alwayz there. U dont work in the city 4 a year and a bit and not make good friends with all the low lives in there.
jaq: they are d-speed. Pretty rare in oz, in fact i don't think i have seen them on another car. Its the same as my giant wing (which i still have on the car).
www.dspeed.co.jp and check out the ECR33 i think bodykit. You will see the skirts there. I never knew what they were myself until a couple of months ago :(
thanks
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
