  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah, um the concensus seems to be not to push too hard when out there tomorrow. Also I was considering a way to solve the getting lost problem would be, instead of someone decided that we're leaving and everyone running for their cars, to get everyone around for a few minutes and explainthe route we're taking. Everyone having a bit of information might help the problem. Just an idea.
yep.. i have about 10 cruise maps printed which some can have.. but am relying on most people printing their own copies or tracing it out in their UBD beforehand.
Also was planning on giving a bit of a speech/blurb as to where exactly we are going before we set off yeah.. i think that would help.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
