  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I know it's also got Natalie Imbruglia in it too. And why did you offer me ten points if you can't award them to me when I get it right? Huh? I thought google was your friend.
If anyone can spot the tortoligy in this post I WILL award you ten points. Unlike Ska's fake ten point award. :(
Wow you know it is amazing fo someone who does not post in here any more mindflux is still in the top ten, just think of the battle it would've been between him and chaos for top whore, I reckon mindflux would give chaos a run for his money!
Ska it goes a little sumthin like this. Hard work sometimes pays off over time. Procrastination always pays off now.
Yeah not looking forward to tomorrow, getting chewed out for projects which had completion dates 2 to 3 weeks ago, but not blaming anyone but myself, just dont seem to have the motivation right at this point in time............
yeah, but look at how much you've "achieved" on here. I'm kind of the same atm re the motivation.
I just cant stp think about skylines, what mods I want to do, when is the next meeting, when are we going to the drags, what time will I might get, what kind of put down will strutto use next.........
Seriously, I think I am addicted, is there skyline patches you can get?!?! :(
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
