  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yer i dont think ill have my usual passenger but i gotta go to brisbane to pick up some other stuff so i might stick around for the meet and then head home
Cool I'll have some company on the way home den :(
im lookin through justjaps site, i love looking at parts i cant afford
nice warm feeling isn't it , reminds you of why you go to work .......... and for food and living as well .
