only downside is, the green won't look nice on a silver car I think
Yeah I think it is only for black cars, which is handy :D hey did you put that sunroof in yourself?!?!? looks like you did an awesome job!
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i nearly lost my licence on friday
double demerit points over here and I got done doing 116 in an 80 zone .. lost 8 points and $250.
Thankfully its my first fine in 7 years, so I've still got 4 points left :D
Man that sucks, no double demerit points here in QLD :devfu:
