I'm sick :) Got a head cold.
But besides that, I can't eat that type of food. I get very sick. I have no gaul bladder so I can't eat very fatty/greasy foods and unfortunately, asian foods is one thing I have to miss out on.
bummer....hope you'll be OK for tomorrow....but I suspect you could be on your deathbed and you'd still drag yourself out for MSCII
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
since you are coming down from the airport, you will be on Ann St.  You will prolly need to get on Gipps Street and turn onto Wickham Street.  Once you turn into Wickham Street, keep to the right.  Try to find a place to park or if not, take the first right into the carpark.  Cybercity is across the road NEXT to a ANZ teller.
hope that helps :)
Is it IN the chinatown mall?
He can't do that. He'll be weighed down by three people then :)
lol...well 2 people and a small watermelon
I have asked her but she has been getting tired pretty early these days and I wouldn't want my night to be cut short with a "can we go home now?", prolly at about the BWCP stage....so in answer Ben....NO :D
