Warwick?! It was you who got owned??
What'd you do/
was being silly and shot past this chick in a celica who was antagonising Glenn....didn't realise there was a cop following us in an unmarked car
He was pretty good about it....said he was going to pull over the celica for being a dick, then I pulled my brainiac move so he decided to do me.
He actually asked me how many points I wanted to lose, so I think he adjusted a few details for my benefit
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
was funny...he goes ..."where have you been?....at the carpark?: and I said "nah just for a drive to Fingal"....then as he was looking down writing the ticket (I was sitting in the cop car with him), this stream of skylines fly past, and I was praying he didn't look up :)
mighta been a bit obvious
Bub is due in September, so if I go for 3 months without it's all good, which is prolly the best option, coz I can't see myself surviving on 1 point for 12 months....I just don't have that kind of self control :rollseyes:
The cop asked me how many points I had left and I foolishly said 6, so as not to sound like a regular offender....if I had said 2 he might have only done me for one point....DOH!!!!....he was actually a preety decent guy...asked all sorts of questions about the line etc and wasn't condecending at all
Good thinking.. I was more thinking of the bub and the rush to the hospital with no licence...
:sorry love, you'll have to drive yourself, I've got no licence"
yeah....just catch a cab....I'll call one for you now....no rush is there? :P
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
