  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
u sure it was turbo?
ive been out there before and there was a 944 porsche with a v8 in it
positive....owner was crapping on about it quite a bit
didn't have much more to say after I passed him down the fron straight and proceeded to put a lot of real estate between us
OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG OMG
JUSTCARS SENT ME A QUOTE $2800 NEXT YEAR FOR A R34 GTT STOCK :D:d:d:d:d:d:d:d
