  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
seeming ur 21 and livin at coast hit up the beach and gets some hot uni girls numbers :D
roflmao. Sif. The grass is allways greener on the other side of the fence.
Anyone want to sit in front of a computer in a badly lit office with no sky or window or sunlight. :blah:
i got brickwalls to the left right front and back of me, crappy fluro light, stuiped cheap government aircon system and damn ABC radio : :Bang:
