  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
skygirl
mmm bit suspicious she has no posts to her name
yeah, she's probably sifting through pages and pages of worthless carp, whoops, crap I mean. or perhaps she's just a noob who wants to buy a line. either way when you read this PM either me or belgarion and say hi.
Or
we'll start a thread on you, like the mystike one. :D
