  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i like this
Mods include a double dump 3" brand new mandrel bent exhaust system(value $1100), a GFB Stealth FX Blow Off Valve (completely adjustable, can be silent or Very Loud), GFB boost controller and Speco boost gauge with chrome cup, Speco 5" monster tacho with shift light, New NGK Iridium spark plugs and ignition coils, New front brake pads, New valve timer, New Timing belt, 6 stacker CD Player. All new fluids and filters, drives like new. Very promising car, perfect for modifying, no internal engine problems because i have spent alot of money fixing every aspect of the engine. 7" LCD Screen in glove box. PRICE IS NEGOTIABLE.
and its been on the site for a while now.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
