  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hows those batteries, if you use them tonight you'll have to put on charge the second you get home and try putting them on for as long as possible before the sunday cruise, we do not have a car charger for it and I cant borrow any more batteries, boss is jumping up and down already why I have not brought it in and signed it in and then out each day, lucky I made up some bullsh¡t story bout kids playing with it and leaving it at ex's place :thumbsup:
If I buy a radio it will be an incar, not a pissy little hand held, NOT that they are not good, hmm just spoke with the boss and I might be able to buy one through work and pay it off through pay deductuion :thumbsup:
Yeah but we buy those top of the range ones, they are like $900 each, have range of like a billion KM's and they are literally unbreakable, we have the same brand in all of our trucks and not one has been able to be broken yet, and you should see how they get treated by the drivers................... not too well, plus I can pay off at like $5 per week for a billion weeks :thumbsup: no interest :)
