Sorry beau, didnt see ya there, posted and left for home expecting to spend some time with a cop doing the incident report for the real estate, good to see cops dont turn up to appointments either!!!!! NOT HAPPY JAN! I could be out doing something, friggin cop!!
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
