  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
And i should know, I have killed for much less in the past, What? ................................................................ Oh yeah forgot, dont tell anyone ................................................................. What, I have to kill him now bcause he knows ......................................................... ok then
Hay since nothing will be going on with my line for a while , you can BORROW my super dragger if you want
Although tempting, the answer is no, it is yours man, dont lose heart, it'll go on your beast and it will ROAR!
I don't know how much longer you will keep the rice crown , I was looking at neons on the weekend , oh yeah and I saw a line with the thing we were going to do , a neon in the rear boot to make his SKYLINE plastic bit shine blue, the idea steeling bastard I was going to run him off the road
