  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I don't know how much longer you will keep the rice crown , I was looking at neons on the weekend , oh yeah and I saw a line with the thing we were going to do , a neon in the rear boot to make his SKYLINE plastic bit shine blue, the idea steeling bastard I was going to run him off the road
Oh well, I have not seen anyone, even non-skylines with green calipers yet, or racing stripes :D
I was going to get neons, but i would want them on all the time, and i know the first cop I pass it'll be BAM DEFECT CITY!
