  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
cyrice is right though....im not working with the best people in the buisness
first thing i learned.....dont talk to anyone just do your work and you wont get in the shit...more than what i could say for the guy that was supposed to help me....first day and i need to know things like the back of my hand.....been thrown even deeper now as im on my own.......
but on a lighter side..........its great living here :D cyrus has given me and opportunity and i've taken it........as he said im not working with the nicest or smartest lot but hey i leave them alone and they leave me alone
