Yeap Kids weekend next one so I'll be there :D Kayla does Tap and Jazz too, so I'll be there from 9 to 10:30, but that if she wants to go, she missed out on a couple of weeks and doesnt really know the dance which kind of discouraged her, but now that she's back into it she wants to go, but there still could be a chance that she wont want to go so, might let you know closer to Sat :D
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i'll have to sneak in quietly.....bit hard as shae can hear the car a mile off.
i get in trouble for watching too!
been a while since i have been. i get heckled by the mums. they call me the flower man cuz i always used to send shai flowers to dancing. so trying to keep low profile hehe.
maybe we could hose down the super cheap carpark and turn it into a skid pan.....
Hey now that is a GREAT idea! :D
Well now I have a HKS Super Dragger on she'll hear me coming too:D BBBBRRRRROOOOMMMMMMM!!!! ;)
Wouldnt it be funny if I did get a spot in front and backed in, give everyone a blast! :D
