  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i got called away because of a fire drill.... walked down 11 floors or stairs
yay.
i was worried cyrice would get 25 posts in a row while iwas gone.
Dont you worry, there is always 5:30am tomorrow morning when I start work :D mAUaU AHHA hah ah aH AH H AH AH a hhaha Aaaa! :D
