  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i've got a mate who builds engines for pro stock cars. Ray Hon Fayeh (chinese dude - so funny seein the little dude in an xd doin massive burnouts, hes so happy when doing this). anyway, hes done a new engine config, quite awesome.
Ford 351 windsor destroked and bored to 344ci. revs to 9200rpm and makes 700hp. :D early days.
huge revs james. SVO ford motorsport crank and 6 bolt main iron block. runs nascar A3 alloy heads ported to the max. he sells these heads for $30,000 (yes thirty thousand dollars) a set. carillo rods etc.... very expensive motor. he also does heads for a few v8 supercar teams.
