  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
nope you got it all have ya, from where?
I got the setup32.zip too, have not had time to test it as still on crappy lappie and cant really install much on it.
From that link in the thread...
It installed OK, but does nothing when opened... Have to try another PC...
