  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
how does that work? does it blow back into the engine on the MR2's ???
On the skylines generally they just blow out the ass end, although its most of the time the exhaust wheel on the skylines that givesway more than anything -- they are the ceramic bit.
gday charly
gordon yer they say very soon
apparently he had a small problem when they started tuning but its been overcome
*starts singing*
we will overcome......
*ends singing*
hey james. :wavey: net's playing up so I might be here one minute then gone the next. Sam wants a passenger james. If you didn't know.
some times it can cause a pulse or something and a vacuum is made and bit go into ur engine :P can happen on skylines to just its rare. but if possible.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
