  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I really like the V600 and am thinking about getting it when I upgrade in a few weeks. Andrew' doesn't like it because it's a "powder puff phone" But meh, I'm female!
Cyrus, seeming I've been driving brutis for the past three days, I was thinking of taking him to willowbank to race :P Seeming I've had practice driving it.
Pfft.. I love my cooler. $2000 is installed if you get through customs. If not, it's $2000 + $400 installation (at the most, depending on the kit and how much modiciation is needed)
How much are the blitz kits? IIRC they are around $1500. I know which cooler I'd rather have for $1500.
