  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
you are so whack josh. Are there any whorequeens around today? A bird flew into a window when I was at home yeserday and as far as I know broke it's kneck and died. At least I think it did. I couldn't be bothered to go and look. I guess when it starts smelling in a few days I'll find out. eco eco economists do models.
