  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Beau...  Was thinking Sunday for dodgy mech day...  To help you out with your bits and give you that front pipe...
But it's Fathers day...  :)
Are you free on Monday?
Pred:  I have a stock dump in poor condition if ya want...  Cost $20...  Comes with free K& N panel filter...
mon arvo would be good , I finish at 4 can be at Beenligh 5:30ish if thats cool
We could do it sat morning if you want to come round, I dont mind either way I'll be home and doing nothing both Sat morning before go-karts and monday night, so yeah I'm good for either day!
Just remember i only own a philips head screw driver and a small shifter :)
OH and can anyone find Benji's 8 page Conan post fit? I know it was on a cruis night, but cant seem to find where abouts it is, I want to count up how many posts in a row it was, but cant seem to find it via search, and I'll be buggered if I am going to go through pages looking :)
no no no you guys have it all wront, it goes like this:
I'm a little tea pot,
Short and stout,
Here is my handle,
Here is my spout,
When I get all steamed up hear me shout,
Then tip me over pour me out!
Now for the actions too.............
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
