Hi everyone,
I'm selling my 2005 Silver 250GT V35 sedan and done 50,000kms.
Features:
Privacy Glass on rear of car
Clear Side indicators
Cruise Control
Dual Airbags
Dual Climate control air conditioning
2xIKeys
Xenon automatic-on/off headlights
Factory 17" wheels
Rear Lip Spoiler
Reverse Parking Sensors
Earth Kit
Momo Silver Gear Knob
LCD TV screen and aftermarket headunit
Sports tiptronic mode for manual shifting
Still under premium extended warranty, 2.5 yrs left
Full service history in Australia
After $19,500
This car has been well maintained and has been serviced every 5,000 km. It is garaged every night.
The VQ25DD 2.5 litre Neo direct injection engine provides excellent sporty performance combined
with a smooth comfortable luxury ride.
Car is in Melbourne and any queries please contact via PM.
Here are the photos:
https://www.sau.com.au/forums/topic/343399-melb-2005-skyline-v35-sedan/
Thanks hopefully we can sells the V35!
Anyway here are some updates:
Bosch Aerotwin Wiper Blades
Nissan Floor Mats
Nismo Sports Pedal Covers
Pioneer Mp3 / CD Player
SxExCx Custom Grounding Kit
Skyline Trunk Side Separator
Also the car had been detailed by Final Inspection on August and come with the V35 Skyline Handbook with Touch up pen.
Oh yer car just over 50k kms and had a service done too.
Here are some more photos:
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
