JDM 1999 Nissan Silvia s15
Km: 91000 km
Transmission: 6spd Manual
1st Aus Owner, car purchased from dealer in Feb 2010 with 80000 km and still has 2 years transferable warranty.
Never seen a track, very reliable, I have never had an issue with this car.
Exterior:
-Nissan Aero Bodykit with ducktail spoiler
-Rare electric sunroof
Wheels:
-Genuine Rays Gram Lights light weight drift wheels(unmarked)
Engine:
-Tomei Expreme Exhaust Manifold
-K&N High flow filter
-Front and rear struts
-Gizzmo MS-IBC Boost Controller
Suspension:
-Pedders XA Coilovers which are ride and damping adjustable. Purchased for $2100, less than 7000km old with 1.5 yrs warranty left.
Exhaust:
-3.5" exhaust with removable silencerInterior
Interior:
-HKS Boost gauge
-Genuine Nardi Steering wheel
-Yashio factory digital water gauge
-Sony CD/MP3 player with USB input
-Yashio factory gear knob
Security:
-Mongoose 4-Star alarm system with backup siren
Tires:
-about 10000km's old, 80% tread
Service History:
-Serviced every 5000km
Warrantly:
-2 years MPL warranty remaining (warranty worth $1200)
Very regretable sale, I don't have the time to drive this car so its time to sell up. Car can be viewed in St Kilda or Mount Waverley
Car is $21500 without the aftermarket wheels, with the wheels $23000
PM or phone 0431045525 for details/enquiries.
pics to follow
Pretty good price here people, I picked my aero s15 for bout this without any mods.
Good features too, sunroof and factory HIDs.. jump on it people!
  • 4 weeks later...
Does it come with stock steering wheel?
as you would not be able to get RWC in melb or innsurence with a airbaged removed
i dont have a stock steering wheel, the car is as is with no stock parts to substitutefor the mods, this was how the car was originally purchased by myself
  • 3 weeks later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
