Hi
I'm in the process of importing a 1999 RS4S through Iron Chef and have a couple of questions about some parts I have been thinking about adding but I'm not sure if they are street legal here in Tassie or not, so I'm hoping someone might be able to help out. Can anyone tell me if a carbon fibre bonnet is legal? Or a Varex exhaust?
Thanks
Tim
https://www.sau.com.au/forums/topic/343488-modification-questions/
<br />Just ring service Tas to confirm legality of the cf bonnet . how big is the exhaust ? usually have to fit a pretty stock exhaust for compliance .<br /><br />
<br /><br /><br />
The car looks to have a 2.5 or 3 inch exhaust system on it (just waiting on exact details), but I'm thinking about fitting one of those Varex mufflers with the valve that you can open or close to make it loud or quiet, and I'm not sure how legal they are
<br /><br /><br /><br /><br /><br />The car looks to have a 2.5 or 3 inch exhaust system on it (just waiting on exact details), but I'm thinking about fitting one of those Varex mufflers with the valve that you can open or close to make it loud or quiet, and I'm not sure how legal they are<br />
<br /><br /><br />
Update - just spoke to Service Tas and the guy I spoke to did not think the bonnet would be approved because of the potential impact on crumple zones and the car's safety system, but that the Varex muffler should be ok as long as it complied with volume limits.
Any thoughts/experience that anyone else has about cf bonnets or the volume of Varex mufflers would be still be appreciated!
Hi
Thanks
Tim
good to hear another manual in tas, I think we have the most manual stagea's per state then any other!! you located south, north or coast?
I'm in Launceston, can't wait for the car to get here!
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
