weekend bump! rear seats 50$,indicator and wiper stalk 25$,diff 150$,manaul conversion pedals clutch master interior boot trim 150$,left gaurd perfect 80$ lots of other stuff to just pm me.
wrecking s1 r33 in silver im keeping these parts but everything else for sale, the car has rear end damage
KEEPING: gearbox, front brakes,tail shaft,steering rack,front lower control arms,
THE ENGINE IS A SERIES 2 complete engine, loom,ecu
completely stock, never even been boosted.
still in the car so can hear running, compression and any other tests welcome....$1800 $1600
OTHER PARTS:
bonnet $100
S1 front bar $80
lh guard with indicator $100 each $80
s1 headlight $80 each
rh complete door $150 each
s2 spoiler $50
rh mirror $30 each
type m sides fiber glass $100 $80 needs bit a work
fuel flap $10
rear window $100 taken out
quarter glass $80
radiator $100
condenser $50
condenser fan $50
master cylinder non abs $80
washer bottle $20
cluster $100
dash $100
mint air bag steering wheel with clock spring $140
seats $100 pair
glove box $20
console $40
door trims and 1/4 panel trims $40 each
seat belts $20 each mint
indicator and wiper stalk $25
rear seats $40
diff $150
manaul conversion pedals clutch master interior boot trim $150
anything else just ask, will swap for parts of interest!
LOCATED IN ADELAIDE ...TEXT or CALL on 0422030855
Edited by hcR324door
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
