See "whole cars" forum for details and pics.
Engine - great
Interior - great
Body - minor rust only
Brakes - need work
located in Mullumbimby, Northern NSW
More pics: http://www.dropbox.com/gallery/10948805/1/...kyline?h=abe26d
email: [email protected]
Cheers...
https://www.sau.com.au/forums/topic/343915-1978-datsun-skyline-all-original/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
