Running No Thermostat
Guest trikdoutvl
Simple question, will running no thermostat make my rb20 run hotter? I had my car overheat on me and the cultpret was a bung thermostat.. So I pulled it out and now the car runs at around 190-200f. It tends to creep up when I am idelling at the lights. Just wondering if removing the thermostat would have caused that or should I put a new 1 in??
https://www.sau.com.au/forums/topic/343942-running-no-thermostat/
I would have thought no thermostat would just mean it takes a lot longer to warm up which isn't a good think, If its a daily I would deffinately put one in..
Buy a thermostat, you probably have a circulation problem now . The thermostat blocks the bypass when it opens up and allows water to flow through the radiator, so hot water is probably recirculating around your block.
Pulling thermostats out only works on old cars.
pulling out a thermostat will cause ur engine to reach full operating temp a lot later meaning more wear and tear. it will not cause it to over heat
put a thermostat back in, if its overheating with a new thermostat in there you have a problem
Guest trikdoutvl
I should of added I had the radiator flushed the same time I took the thermostat out..... My temp gauge is aftermaket and in farenheight.. Is 190-205 normal temp for a 20? It goes up down between idalling and driving. I was thinking of installing thermo fans next.
i noticed in my car it ran much cooler but it can screw with electrics with your EFI, when your ecu depends on water temperature to decide how much fuel it needs to put in when u start car and so it knows when car is warm to convert back to normal map.
thermo's block flow to the radiator until the car warms up, then open to allow it to stay at that temp via radiator cooling. your car overheated cos the thermo was stuck closed causing it to be in the "warm up" stage until cooked.
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
