Condition: Used
Reason for Selling: dont drive it just sits in the shed
Asking Price: 25000
Delivery Methods: PickUp
Contact Info: 0434012067
Extra Information:
hi guys here i have for sale is my 400hpatw r34 1999 5 speed manual skyline.iv had it just over a year i got it priti much stock it has 104k on the clock i hav done about 1500k of that it is a very wel lookd after car.i hav 3 other skylines so i never get 2 drive it.all the parts on it are priti much brand new they havnt done over 500k the work on the car has been done by pete at petes fab.gaven wood auto tec.and a lil bit by jeff at nisspro.
it has
tsr 660 turbo
38mm tial wastegate tial 10pound spring
greddy copy intake
80mm bilit tb
aftermaket fuel reg
custom made incooler piping
hks fuel rail with custom made spacers
sard 550cc injectors
700hp fuel pump
r32 gtr custom made bov
custom made dump pipe
custom made 3inch all the way throw with twin drift pipes sounds f*kn sick can here the turbo spooln on idle
ica alloy rad
twin fans with thomo swith
exedy button clutch
blists suspower air filler
z32 afm
hks cam gear
splitfire coil packs
defi gauges oil pres and water temp
calibre boost gauge
greddy profec b spec 2
power fc with hand controler
7 inch dvd player jvc
recaro drivers seat
short shifter
custom made adr roll cage with custom made pading wasnt cheap lol.
teins coilovers
adjustable rear camber arms
adjustable rear toe arms
works xd9s with brand new federal tyres.18x9 245 on front 18x10 255 on rear
full body kit
4 point adr race harness
i do have all the back seats aswel.
im sure there is lots more but if u r keen give me a txt or a call and u can come see for your self.
car made 402hpatw on 19 pound but is only running 14psi atm and yes i do have dyno sheets we have just moved house so i will hav 2 try and find thm.
this car is a very good car az i send b4 all parts r priti much brand new and hav nt done of 500k.
im lookn for swaps cash both way or just cash let me no what u got thanks.
theres some more pic hea
http://www.boostcruising.com/forums/index....&id=1278944
http://www.boostcruising.com/forums/index....&id=1278968
http://www.boostcruising.com/forums/index....&id=1278974
http://www.boostcruising.com/forums/index....&id=1278971
http://www.boostcruising.com/forums/index....&id=1278962
Edited by maniekan
  • 3 weeks later...
  • 1 month later...
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
