ok, i have an issue. when i drive the car normally and a little on boost its ok. when its on full boost and i take my foot off throttle i get this disturbing grind/vibrate in my car which is noticable both by feel and sound. any ideas. im just hoping its nothing. a stuffed turbo would suh as i have only had the car for 2 weeks. any ideas, info would be good. im freaking out.
https://www.sau.com.au/forums/topic/344519-disturbing-vibration/
Josh,
This might be a big guess, but I would assume it might be a CV joint? Is it more like a click? Then this would be a CV.
Does it sound like it is coming from the back or the front?
How many K's has the car done?
If its making boost it probably isn't the turbo, do you have an aftermarket bov or any other mods you know of?
Is that the only time it does it?
What's your location, I could have a listen if you're in Melbourne...
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
