hey guys have a Impul Blast exhaust for sale since i just took it off my r33 gtst. it is a 3" mild steel pipe with a stainless oval muffler. Jasma certified and very quiet although i must say it sounds pretty good when you give the car a boot. Japanese quality exhaust that you don't see around alot.
the exhaust has been cut and rewelded in Japan and it looks like it has been done in order to tuck it up more as it did sit quite snug and high into the body. this has made it one piece from the cat back. not an ugly reweld job at all. exhaust looks nice and clean and is in awesome condition.
$150firm and pick up in western suburbs, vic.
0432454387
thanks mate!...yeh indeed very quiet and close to stock on idle but when on boost it sounds awesome. still for sale
many people telling me they wil lget it but no one following through. still for sale guys...need it gone asap.
also have my 33 for sale take a look
http://www.skylinesaustralia.com/forums/19...88#entry5571488
can also vouch for a great exhaust right here, i have on on my 34gtt from a 34gtr, quietest idle for a 3inch system i have ever heard.
GL with the sale
kudos go out to jake, great guy to deal with, id encourage anyone keen on a clean 33 to check his rig out :D
posting here cos the trader rating system appears to be gone :thanks:
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
