hi all as all you can see im parting out my r32 gtr that ive had for 5 years now, im wanting to put back to close to standard and sell the car as it is with no mods to it as i have to go through EPA so i cant really afford to put all parts back on, the parts are all quality parts have never took a short cut on this car in the last 5 years, car is still running fine, it makes over 300awkw on 18psi safely, parts i have are:
HKS gt25/30 turbos with hks actuators
tomei dump pipes, the hand welded ones that apparentely are better and are a 2 3/4"
greddy 100mm trust intercooler with the greddy aluminium pipes, greddy hoses and all the heavy duty clamps
apexi power fc (doesnt come with handcontroller)
nismo 555cc injectors
z32 afms, tomei plugs with the custom piping for the z32 afms fit the r32 gtr, come with almost new apexi pods
blitz DSBC
nismo fuel regulator
sard 280 fuel pump
impul 3" stainless front pipes
n1 head lights
blitz BOV's
hks 3.5" stainless cat back exhaust system
like brand new recentely installed Tomei 260deg 9.15mm lift cams
greddy cam gears
clear cam gear cover
like new cusco zero 2 coilovers
ARC aluminium radiator
greddy aluminium raidator pipe
carbon fibre bonnet, not sure but looks like a D-speed payed $830 from a sau member a little while ago
morosso oil catch can
parts are still on the car but i can take a few pics or if yous want to come and inspect the car as im in melbourne located in the northern suburbs,sms or contact anthony on 0412862091 anytime or PM me but im not always on here
the car will also be for sale or i will sell as it is whith the parts still on it, its in abbroad minded personely sparkling condition probably one of the best r32 gtr's out there but car has really made me go broke and cant afford to take parts off and put back on, i havnt received the letter from EPA yet but they wrecken i will get it in the mail,
thanks for your time guys cheers
Interested, not paying more than 790 coz thats the new price at justjap.
Closed.
No prices listed, not to mention I am quite sure you are not the owner of these parts and are advertising them on behalf of a banned user.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
