Hey just helping a friend sell his turbos. Up for sale is 2x GT2860r 400hp rating each turbo. Good upgrade from the stock turbos on your rb26. He's told me they've only ran less than 10,000ks so still near new.
asking price: $2,500 o.n.o
-thanks.
Edited by JnJ
https://www.sau.com.au/forums/topic/345315-gt-2860r-400hp-each/
-thanks.
im assuming thats a -5 set not -7?
GT2860R is Moreso -10 Set So HKS GTRS equivalents
I Reckon would need big cams to help it breath
Compressor Housing|Compressor Wheel|Compressor Wheel (mm)|Compressor Trim|CompressorA/R|Turbine Housing|Turbine Wheel|Turbine Wheel (mm)|Turbine Trim|Turbine A/R|Cut back|Core Bearings|Comments As pair
Garrett 707160-10|GT25|GT25|51.2 - 71.0|52T|0.6|GT25|GT25|47.0 - 53.8|76T|0.64||BB|~800PS
HKS GT-RS|T04E?|GT25|51.2 - 71.1|52T|0.6|T25|GT25|47.0 - 53.8|76T|0.64||BB|~800PS
-5 is bit smaller
Garrett 707160-5|GT25|GT25|47.2 - 60.0|62T|0.6|GT25|GT25|47 - 53.8|76T|0.64||BB|~640PS
Edited by krayzie32
-thanks.
Tell your friend to signup then.
FYI, i brought 2x -5s new for $2200 recently. And various SAU traders have then between 2400-2600.
To ask $2500 for 2nd hand turbos... lol... Inform your mate he is kidding himself.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
