Hey guys,
I only got this car about 3 months ago. I want to get into an S14. I just sold my S13 and prefer the S series, hence the sale.
I'm willing to swap for a stock S14 (series 1 or 2) plus cash my way, or a straight cash sale.
Apexi EL boost gauge
Apexi PowerFC aftermarket ECU
Apexi AVCR electronic boost controller
3" Exhaust
Heavy duty clutch
Pods
Advan ONIs
Alpine headunit
Drift gearknob
MOMO steering wheel
300km/h dash
Tinted windows
Nismo oil cap & radiator cap
Strut braces front and rear
The car has 170,000km on the clock. Previous owner said that it has had a replacement motor put in with 80,000km on it. Happy for the potential buyer to have the motor compression tested as its in good nick and had it tested myself before I purchased it!
It makes 200awkw on 12psi. Will make more power with cam gears (will come with car), boost controller set up correctly and a new Cat. Chassis rails are as straight as an arrow.
The bad bits: Paint isn't the best, could do with a respray. Rip in drivers seat, could stitch or just use a seat cover. Aircon could do with a re gas.
I have cam gears, alternator belt, front camber bush kit, tie rod ends, steering rack boots that I can give away with the car. If it doesn't sell immediately i'll put them on.
Rego until November 11 2011
Any test welcome!
$16,000 Neg. or swap for S14 (series 1 or 2) Prefer a stockish car.. Will consider straight swap for S15
If you have any questions or would like more information please don't hesitate to call or PM me!
Located western suburbs, Melbourne
Rick 0431 456 627
https://www.sau.com.au/forums/topic/345813-r32-gtr/
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
