hi guys, unfortunate circumstances have changed my current build plans and this lovely piece of work from CPC plenums has to go. :(
This will suit a R34 GT or GTT or Stagea NEO.
Will also bolt up to a R33 RB25 DE/T but the runners used in this were from a R34 RB25 neo motor.
If this is fitted to a R33 RB25, then you will need NEO style top feed injectors.
Clean welds, excellent quality. check out his thread in the fabrication section or visit his site.
http://www.customplenums.com/
Item has been fitted, it has been sandblasted before installing but dirty mechanic hands have touched it so there are a few dark spots around but nothing a clean and polish cant get rid of. :D
This has been made to suit the stock RB25 throttle body (can also be adapter to suit aftermarket throttle bodies also).
No flange for IAC has been made however Ariel can make this one up for you at no charge. Just mark where you want it, and take it to Ariel and he will do the rest.
I was initially going to remote mount my IAC so 1 nipple has been tapped to accomodate this but can easily be removed/blocked or used as a breather line for the rocker cover.
PICS:
*before clean*
fitted
PRICE
purchased off Ariel for $900, selling for $700.
Will also be willing to swap for a R34 GTT or Stagea RB25DET NEO plenum (top & bottom pieces) + cash adjustment my way.
item is located in Sydney.
Can post interstate at buyers expense. Please contact for shipping rates but i dont seeing it costing more then $50-$70~ to AUS wide with registered post.
Thanks for looking.
https://www.sau.com.au/forums/topic/346055-fs-r34-gtt-neo-custom-plenum/
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
