Has anyone successfully installed Nissan's FAST parts database to a laptop so it doesn't need any CD's? I want it on my laptop showing just Skyline models, ideally, and don't want to have to use a CD in the drive bay. Thanks.
i do. i never had the cd's to start with (downloaded it). i just loaded the setup file, followed what i had to do there and then just had to copy some file into the windows folder and it was all done.
Yes - i have it with no CDs. I installed it years ago and IIRC there was a file with some instructions included. I'll have a look tonight. I think it was about 4 gig all up, so I assume that means its everything.
From memory you copy all the files from the cd to a directory on your hard drive. Then you open the FAST setup program NFSET.exe and click the CDROM Setup tab. In there you can point Drive 1, 2 etc to the directory on your hard drive where you copied the files.
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
