Hey well a few of us were talking about stickers last time I attended a meet, and was told to PM Gary1, I did but replies are few and far between, so I did some searching and it looks like we can order them for the same price from a SAU banner sponsor, detailed in this thread:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=34280
So I got mine on order, cant wait!
https://www.sau.com.au/forums/topic/34665-sau-stickers/
Man you are lazy Zoix! If you went to that thread you would have seen this link:
http://www.street-weapons.net/store/browse...678ea5c1,,.html
and no you dont need credit card, just choose the wire transfer and he accepts direct deposits, so that's what I did as I dont have credit card either :)
That and I didnt really want the banne, just the side one, so I just ordered them, $5 with free postage, you cant beat that!
https://www.sau.com.au/forums/topic/34665-sau-stickers/#findComment-693466
  • 3 weeks later...
and no you dont need credit card, just choose the wire transfer and he accepts direct deposits, so that's what I did as I dont have credit card either :P
Just ordered my stickers. i ordered the 2 small ones. the big one aint to my taste.
https://www.sau.com.au/forums/topic/34665-sau-stickers/#findComment-718023
Yeah I only ordered the small ones too, just be carefull putting them on, stupid me did not know they are not directional, but I made them :D after a bit of fiddling :)
The big one does not look too bad, I got one too so I stuck it on, might replace it with one that has slightly bigger writing, but they all look awesome on a black car, white on black really stands out!
https://www.sau.com.au/forums/topic/34665-sau-stickers/#findComment-718312
Maybe we need a short picture tutorial to show people how to apply them.
I've got the stickers just haven't put them on yet, cause I am waiting until I clean my car and I am extremely lazy :D
Might do it on Thursday night while we are waiting for everyone to show up and then we can take photos at the same time.
https://www.sau.com.au/forums/topic/34665-sau-stickers/#findComment-718355
Yeah I didnt think it was too hard, just got to have a steady hand and start off where the letters meet the circles and then go out in both directions from there, problem was that I wanted both side of my car to look the same, so I stuck the passengers side circles on upside down, which meant the little bit in the middle had to go because then none of the lettering fit, also had to move the skyline top lettering across and try to line up the bottom fron red circle, lots of fart-assing around, but got the look I was after :D
https://www.sau.com.au/forums/topic/34665-sau-stickers/#findComment-718367
I think the generally accepted rule is to use a spray bottle (garden variety) with a small amount of detergent. Spray the area where the sticker is going to gi with a light film and then apply sticker. the liquid and detergent allows you to move the sticker around and push out any air pockets before its sets in its final position
That's the method I have been told when applying vinyl stuff anyway....give it a go...works a treat
https://www.sau.com.au/forums/topic/34665-sau-stickers/#findComment-718435
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
