It was attached to the gearbox sump plug! :Bang:
haha ..... argh ..... faaaaaark ....
Put Motul gear 300 oil in there .... helped a little bit but still crunches badly going into 4th.
Any other solutions? Or will I have to get a new box?
Could it be to do with my clutch pedal travel or something, as I just put a new clutch in about a month and a half ago and I'm sure it was worse when I got the car back.
https://www.sau.com.au/forums/topic/34733-finally-i-found-4th-gear/
No oil is going to fix this problem. Unfortunately you have to bite the bullet and buy another 2nd hand box from a wrecker, or get yours rebuilt. It wont be long before the metal circulates and starts busting the other gears too.
What clutches are u blokes using?
I've been running a Xtreem 30% Organic full faced clutch, it has got quite a bit of give in it as a flat change in to fourth will feel a little spungy. Third will chirp though.
I'm about to go the heaviest Xtreem clutch that is a 1058kg pressure plate with a cushioned ceramic clutch that has 12 puks. I know of this clutch holding ~300rwkw with no slippage, (Matt's R33).
I am sure as soon as I go the heavier clutch the box will die.
I've got a 9 puck organic with a 2500lb pressure plate in mine ... before that I think it was a brass button one that came with the car.
I launch the car hard but I wouldnt have thought that it would affect 3rd and 4th (3rd crunches a bit too now).
What sort of money are we looking at to rebuild 3rd and 4th synchros do you know?
Or to get the whole box rebuilt?
I re-counted.. Mine also has 9 puks on either side, the puks look a dull orange with specs of dark grey through out it. Previous organic clutch's I have seen tend to be more light grey, a bit brake pad looking.
A 2500lb is also the same pressure plate as mine.
Do you find it hard on the ol' left leg at a set of traffic lights.
I had a HD clutch put in a VS 5ltr Commodore I used to own, that used to make my leg shake at a set of traffic lights or when waiting to pull out in traffic.
I used to rebuild my 4 Speed single rail box in my TE Cortina, I constantly used to do syncro's & front main bearings.
To replace just the syncro's is just as much work to also slap in a set of new rear and main bearings.
Generally the rattle from a gearbox that you get & can hear when riding the clutch to move forward a little in say Mc Donalds drive through is the layshaft bearings, the lay shaft in the 4 speed g/box was a solid shaft with different sized gears attached, they all moved at once. A solid metal shaft would slide through the middle of this layshaft with hundreds of tiny roller bearings. It takes a long time to replace those as you need to stick them on to the solid metal shaft with grease then carefully slide it in the middle of the layshaft hoping you don't hit the sides to much as to dislodge the roller bearings. The layshaft bearings don't have to be replaced and generally arn't. I had the VS 5 speed g/box rebuild and specifically asked for the layshaft bearings to be replaced. Got the g/box back and they screwed me. The rattle was still there.
I knew from experience with the 4speed that the same rattle noise was definately the layshaft, if I didn't replace the layshaft bearings the rattle would stay.
From memory the parts for the 4 Speed Single Rail box (syncro's, front/rear main bearings, layshaft bearings cost me around $100)
To get some one to fully rebuild the gearbox I was looking at around $800-$900. I could have got jobs done for $450-$500 however I highly doubt they would have replaced the layshaft bearings.
Jimih,
Thought about an RB25 box? Bit stronger than the Rb20 one. Rebuilding is going to cost you a fair bit, gearboxes are labour intensive. Theres no point in doing it by halves either, because as soon as you fix 2 synchro's something else will break and youve gotta pay labour on taking it out again.
Jimih,
Yeah 33 box would be good ... but my car is 4wd so I need a GTR box of some description I think :(
Joel: yeah I think the box has copped a bit of a punishing. The tyres are 255's all round, 4wd and heavy duty clutch. So I think the gearbox takes a fair amount of pain. The pedal isnt too bad on the left leg though :(
The motor's coming out soon anyway so I think I'll just change the box to a GTR box when the new motor goes in ...
Cheers anyway fellas! :D
hey jimih you dont have to buy a new box, my gears were crunching in 3rd and 4th, soi had the gears modified, costs about 50 bucks per gear, and 200 bucks labour, now it doesnt crunch and goes into gear much easier,..
Wreckedhead, where did you get the gears from, were they new gears or only modified the existing cogs?
hey Craved sorry i made a mistake i didnt get new gears he bought new syncros for me and had the modified every 2nd or 3rd tooth was taken off.i had my box stripped to see all the gears and if there was any damage, he told me for a 9 year old box, it looked almost brand new inside, no damage to any gears, the only problem was when i was in fifth it was very hard to gear down to forth, but the new syncros fixed that up stright away, now going through the gears is much easier...
but i can give you the number of a place which can help you modify your box or basically do what you want to it
Joel,
Try telling that to my bucket of bolts gearbox. Pretty much stock standard car just over 100,000k's and it sounds horrendous, like its on its last legs. From experience and listening to many many issues RB20 owners have had with them, its my belief the box isnt so tough.
Red17
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
