-Rebuilt SR20 auto ($3100 of receipts) 20,000kms old in perfict working order
Recondisioned auto, stage 2 shift kit, upgraded tourqe converter, will include tail shaft and mounting brackets if needed
$400
-S15 Seats good condision only a very small ciggy burn on LHS seat base
$500 ono
-Thrashed yellow racing seat
$40
-4 stud setup including brakes
$300
-5 stud Hubs (s14 i was told when i got em no longer need as i sold the car)
$400
-S14 ser2 stock comp $40
-R32 Tails light with surrounds painted white
$60
-S13 smoked tail lights
$80
-S13 Side scerts Genuine URAS
$100
-18" Silver multi 5x114.3 spoke wheels 8" wide +38offset (these are on the front on the red s13 going sideways) toyo proxi up front and slappers on the back
$500ono
-S13 Doors (driver and passager) both perfict working order full electrics and door skins
-$80each ono
-15MM spaces brand new never used
$80
-Autogauge Monster tacho with shift light
$80
-other ramdom gauges
$20bux each (speco and autometer)
-Autometer Boost gauge (mech)
$80ono
-Cadence VXC6KIT 6.5" splits
$100ono
-JBL 6.5" coax
$60ono
I have a whole s13 shell sitting there so i have rear seats parcel shelf steering rack k frame radiators stock springs so on so on plz pm me what u need and ur offer and ill let u know if i have it or if u want pics of anything sms me 0433663833 ill mms u back!
thanks
https://www.sau.com.au/forums/topic/347409-s13-whole-car-wrecking/
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
