3" from the turbo back for the best results, a 3" cat back is purely for noise not performance.
cheers thats what i was after just making sure i wasnt going to loose power with a stock turbo with the 3 inch
https://www.sau.com.au/forums/topic/347523-3inch-zorst/#findComment-5591159
For now install a cat back system and a metal cat leave the dump and front pipe.
When i installed my ATR43G3 the stock front pipe didn't quite line up correctly meaning i had to get one custom made. Might save you a fe $$$ waiting till your turbo has been installed
https://www.sau.com.au/forums/topic/347523-3inch-zorst/#findComment-5591208
cheers mate i might just do that however i do not have a cat what size is the standard cat a mate has a 3'' inlet and outlet cat but has been bashed out that i can have or would a standard vl cat do the job?
https://www.sau.com.au/forums/topic/347523-3inch-zorst/#findComment-5591237
Looks like you will have to go all custom. Get a dump and front pipe made seperatly. That way you only need to get the dump remade.
Better option would be to go the turbo now as you will save a few $100 remaking the dump
https://www.sau.com.au/forums/topic/347523-3inch-zorst/#findComment-5592451
yeah i wont need to change the dump because i will just use the sandard rb25 dump and get it made to suit my mate makes exhaust so money not really a issue and i dont know how long until i get a new turbo
https://www.sau.com.au/forums/topic/347523-3inch-zorst/#findComment-5592474
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
