Hi everyone,
Like topic said, I am thinking of having whitewall on my tires in the future.
I got 19 inch Volk GT-C in gold, and tires are F 235/35/R19 and R 245/35/R19.
I just want to know:
(1). Any experiences with it, plus cost? Pros and cons.
(2). Will whitewall tires look ok on stock ride height? Mine is not lowered at the moment, but still lower than stock ride height because of the low-profile tires.
(3). Where in Perth, WA, can I go to for this job?
Any information would be much appreciated.
Thank you.
Edited by Victor.T
https://www.sau.com.au/forums/topic/347602-whitewall-on-tires/
Hi mate,
I suggest you not get it...why?
Because...
1) It looks gay and "fully sick."
2) The outer walls of your tire has to be shaved which is actually not roadworthy.
3) Doesn't last long - 6 months max and looks crap after that.
4) Looks weird as it's too far from your wheels...I suggest you get wheels with colour lips if you like this look.
5) Not cheap for what it's worth, around $60 a rim, I think.
what about red walls instead, red apparantly is way cooler than white these days...
I recommend neither
Thanks for the idea, mate.
But I don't think it will be good colour combo for my car (White car, gold GT-C rims with polish lips, red walled tires :P ). I think it will be too much colour involved.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
